Introduction
Use this guide to replace the audio control and rocker switch buttons.
This guide requires removing the battery. When reinstalling the battery, refer to this guide to replace your battery's adhesive strips. The battery is pretty tightly secured in the device, but reinstalling it properly will keep it from rattling.
Ce dont vous avez besoin
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
Outil utilisé dans cette étape :Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Outil utilisé dans cette étape :Tweezers$4.99
Peel back the first battery adhesive tab from the bottom right edge of the battery.
Very slowly, pull and stretch one adhesive strip away from the battery, toward the bottom of the iPhone.
Pull at as low of an angle as you can without snagging the adhesive strip on any of the components along the lower edge of the phone.
Don't press down on the battery as you pull the strip.
Peel back the second battery adhesive tab from the other side of the battery.
Again, pull and slowly stretch the adhesive tab to slide it out from between the battery and the rear case.
Continue pulling the adhesive tab until it releases completely from the battery. If it breaks, try to retrieve the remaining length and continue pulling, or proceed as instructed below.
Peel back the final battery adhesive tab from the bottom edge of the battery. Gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case.
Continue pulling until the final strip comes free from the iPhone.
Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
If the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
Then, use a plastic opening tool to gently lift the battery.
Thread the floss or string underneath one end of the battery and pull side to side in a sawing motion to separate the adhesive.
Remove the following screws securing the antenna bracket to the rear case:
One 1.5 mm Phillips #00 screw
One 2.8 mm Phillips #00 screw
Use the tip of a spudger to push the audio control and rocker switch buttons out of their recess on the rear case.
36 autres ont terminé cette réparation.
