Introduction
Use this guide to replace your Nano's display.
Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
Pry the top bezel off the adhesive securing it to the display retainer.
With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
46 autre(s) ont terminé cette réparation.
4 commentaires
And what to do if you break the hold switch?!
Hello, can I connect a 10" LCD display to the iPod display connection instead of it's original display?
No. No idea what you're talking about because even if it was connected it wouldn't physically fit. TV out would be your best friend.
