Aller au contenu principal
iRobot Braava 375t Motherboard Replacement
Ce dont vous avez besoin
  1. iRobot Braava 375t Motherboard Replacement, Motherboard: étape 1, image 1 de 2 iRobot Braava 375t Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Flip device over.
    • Remove the cleaning cloth compartment on the bottom to access screws.
  2. iRobot Braava 375t Motherboard Replacement: étape 2, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the four bottom cover screws.
  3. iRobot Braava 375t Motherboard Replacement: étape 3, image 1 de 1
    • Flip the device back over and remove the shell by unplugging the wire that is holding the shell to the motherboard.
  4. iRobot Braava 375t Motherboard Replacement: étape 4, image 1 de 1
    • Disconnect the rest of the wires and remove all screws that are attached to the motherboard.
    • To remove the wires, disconnect the plastic pins in a similar fashion to the ones in the Battery Replacement guide.
  5. iRobot Braava 375t Motherboard Replacement: étape 5, image 1 de 1
    • Remove the zip ties holding the wires together using a sharp object or thin scissors.
    • If you do not have pliers or a wire cutter available, then you can use the heads of thin screwdrivers to wedge the zip ties enough to remove them.
Angel Ledezma
Membre depuis le 09/26/22
133 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 5-5, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-5, Adachi Fall 2022
CSULA-ADACHI-F22S5G5
6 membres
4 tutoriels rédigés
Un commentaire
How long does this guide take?
Chris Yepez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 13
Total : 147
