Aller au contenu principal
Introduction
This repair guide will show you how to replace the Tape Player Unit by tearing down the device to the point where you can take the unit out and put a new one in.
Pièces
Aucune pièce spécifiée.
  1. Using a philips screwdriver, remove these eight 9.5 mm screws on the left and right sides of the device and place aside. Using a philips screwdriver, remove these eight 9.5 mm screws on the left and right sides of the device and place aside.
    • Using a philips screwdriver, remove these eight 9.5 mm screws on the left and right sides of the device and place aside.
  2. Remove these five 11.5 mm screws and place aside.
    • Remove these five 11.5 mm screws and place aside.
  3. Lift the right side off of the device and place aside. Repeat for left side.
    • Lift the right side off of the device and place aside. Repeat for left side.
  4. Lift the top of the device gently but firmly from the back part until fully detached.
    • Lift the top of the device gently but firmly from the back part until fully detached.
    • Allow the top to rest on the back without reattaching it.
    • CAUTION: Do not lift the top too far as there are wires attached to it.
  5. Batteries pour ordinateurs portables
    Une réparation facile pour un gain en puissance max.
    Acheter maintenant
    Acheter maintenant
  6. Lift up on the tabs indicated to disengage them from the hooks holding them in place. Lift up on the tabs indicated to disengage them from the hooks holding them in place.
    • Lift up on the tabs indicated to disengage them from the hooks holding them in place.
  7. Lift the top up while firmly sliding it towards the back of the device.
    • Lift the top up while firmly sliding it towards the back of the device.
    • CAUTION: Do not lift the top too high as there are cords that need to be detached before the top can be removed.
  8. The second picture shows a close up of the region indicated in the first picture. Remove the small black wire indicated. Grip the wire near its base and pull gently but firmly until it pops out of the slot.
    • The second picture shows a close up of the region indicated in the first picture.
    • Remove the small black wire indicated. Grip the wire near its base and pull gently but firmly until it pops out of the slot.
  9. This step deals with the indicated area of the device. Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture. Gently pull on the cord near it's base until it comes free of the restraint.
    • This step deals with the indicated area of the device.
    • Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture.
    • Gently pull on the cord near it's base until it comes free of the restraint.
  10. This step deals with the indicated area of the device. Lift the indicated tabs out until the restraint looks like the final picture. Gently pull on the cord until it comes free of the attachment.
    • Lift the indicated tabs out until the restraint looks like the final picture.
    • Gently pull on the cord until it comes free of the attachment.
    • The top section of the device should now be free of the body.
  11. Remove the four indicated 12.1 mm screws and place aside. Remove the four indicated 12.1 mm screws and place aside.
    • Remove the four indicated 12.1 mm screws and place aside.
  12. This step deals with the indicated area. Using fingers or tweezers, pull the indicated latch to the right to disconnect the tape player unit from the top of the device. While holding the latch to the right, lift the unit up from the plastic.
    • This step deals with the indicated area.
    • Using fingers or tweezers, pull the indicated latch to the right to disconnect the tape player unit from the top of the device.
    • While holding the latch to the right, lift the unit up from the plastic.
    • CAUTION: When the latch is disengaged, the tape cover may push out and force the rest of the apparatus to pop up. This is normal, but be careful that the tape cover does not pop out too quickly.
    • NOTE: When placing this unit back on the device, you don't need to follow this step, you can simply push the unit into position and the latch will automatically snap into position.
NathanB
Membre depuis le 13/04/2011
239 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 4-1, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 4-1, Regan Spring 2011
CPSU-REGAN-S11S4G1
3 membres
5 tutoriels rédigés
The problem with my micro system pm17 is that the tape drive's head does not work. I noticed that it is a gear that has the function to trigger,The gearbox has probably moved out of its original position and is now not turning the read head.How do I return the gear to the original position so that it re-engages the bedhead?
Rogerio - Réponse
Add a comment
Rogerio - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 17
Total : 2,694
