Aller au contenu principal
Recalibrage des batteries d'ordinateurs portables
Anglais
Français
Traduction de l’étape 6
Étape 6
Recalibrating laptop batteries - READ FOR HP MACHINES, (HP UEFI) 15% lockout bypass: étape 0, image 1 de 3 Recalibrating laptop batteries - READ FOR HP MACHINES, (HP UEFI) 15% lockout bypass: étape 0, image 2 de 3 Recalibrating laptop batteries - READ FOR HP MACHINES, (HP UEFI) 15% lockout bypass: étape 0, image 3 de 3
  • Authors' note: The UI is different as this was taken in 2017; the newer HP UEFI diagnostic layout is shown in Step 10. However, the loop until error steps are still accurate.
  • This will fully discharge the battery. HP diagnostics do not check the charge capacity.
  • Plug the laptop in and turn it on; unplug it once it is on. Press ESC and select System Diagnostics.
  • Open the Component tests submenu. Select Memory or Hard Drive.
  • Select Extensive test. Choose Loop until error.
  • When the laptop shuts off, immediately recharge the battery.
Ceci va décharger la batterie complètement. Les autotests HP ne vérifient pas la capacité de charge.
Branchez l'ordinateur portable et allumez-le. Débranchez-le une fois qu'il est allumé. Appuyez sur ESC et sélectionnez System Diagnostics.
Ouvrez le sous-menu Component tests. Sélectionnez Memory or Hard Drive.
Sélectionnez Extensive test. Choisissez Loop until error.
Lorsque l'ordinateur portable s'éteint, rechargez immédiatement la batterie.
[title] (HP UEFI) 15% lockout bypass
+[* icon_caution] ***Authors' note: The UI is different as this was taken in 2017; the newer HP UEFI diagnostic layout is shown in Step 10. However, the loop until error steps are still accurate.***
[* icon_caution] ***''This will fully discharge the battery. HP diagnostics do not check the charge capacity.''***
[* red] Plug the laptop in and turn it on; unplug it once it is on. Press ***''ESC''*** and select ***''System Diagnostics''***.
[* orange] Open the ***''Component tests''*** submenu. Select ***''Memory or Hard Drive''***.
[* yellow] Select ***''Extensive test''***. Choose ***''Loop until error''***.
[* green] ***''When the laptop shuts off, immediately recharge the battery.''***
