Aller au contenu principal
Recalibrage des batteries d'ordinateurs portables
Anglais
Français
Informations sur le tutoriel
= Terminé = Incomplet
Recalibrating laptop batteries - READ FOR HP MACHINES
    ***''++IMPORTANT:++ ++HP LAPTOPS CAN BE CALIBRATED USING THIS METHOD, BUT IT IS NOT THE RECOMMENDED METHOD FOR "UEFI" HP LAPTOPS++ - THESE SHOULD BE CALIBRATED WITH THE [link|https://support.hp.com/us-en/help/hp-pc-hardware-diagnostics|HP UEFI diagnostic tool] IF POSSIBLE. This method works in lieu of using the HP tool, but the FCC must be checked with the UEFI tool as the batteries do not show the health accurately in Windows.''***
    If your laptop battery is older or reporting incorrectly, it may be possible to recalibrate the battery. This can correct the reported capacity or battery gauge to extend the life of the battery.
    ***''IMPORTANT: Recalibration only corrects the capacity on worn out batteries. There is no way to reverse the aging process.''***
    For help understanding what calibration is, why it’s important, and how to calibrate batteries in other types of devices, check out the [[Battery Calibration|Battery Calibration Wiki.]]
    === ++Guide notes++ ===
    * ***''If your battery exceeds 30-40 °C (86-104 °F), REPLACE THE BATTERY!''***
    * ***''You will likely see a capacity decrease. This is good - not bad.''***
    * ***''Try to avoid using the laptop while it is charging. This may affect the calibration.''***
    * ***''Inconsistent reporting may indicate an EOL battery. Proper care delays this, but it cannot be avoided or reversed.''***
    * ***''If your battery is older, consider a ~10% discharge. A full discharge may kill the battery.''***
    === ++How to recalibrate the battery++ ===
    * Charge the laptop to 100%. Use it until it shuts down and no longer turns on.
    ** See ***''BIOS lockouts and EOL quirks''*** for HP and Lenovo laptops.
    * Immediately recharge the battery. Do not use the laptop if possible.
    === ++BIOS lockouts and EOL quirks++ ===
    * ***''(BIOS lockout) HP laptops have a 15% BIOS lockout and need to be bypassed for a full discharge.''*** Immediately charge the battery once the laptop shuts off.
    ** ***''All HP and most Compaq laptops.''***
    * ***''(BIOS lockout)''*** Some Lenovo laptops have a 7% critical capacity lockout (0190).
    ** ***''Only occurs if the laptop shuts off early. Easily bypassed.''***
    * ***''(EOL quirk) Some Dell batteries hold incorrect data once the battery is heavily worn, or end of life. This issue self corrects with time. I have seen this on a few OEM Dell batteries. Notably, the NX31D (DOM unknown/2x with same issue) 65Wh (2014 DOM/E6440) and a RMJFW 65Wh Extended (2014 DOM/E6220). The 45Wh 34GKR is prone to it, but to a lesser degree (2014 DOM/E7440).''***
    * ***''(Firmware quirk) Some laptops like towill show 0% wear in BatteryInfoView - notably most HP models. In order to access the data with HP, you must run the diagnostics (UEFI mayrequired if yours needs this). In some cases it can be required), or usefound in the HP Support Assistant app by doing a battery check and findunder the advanced info. This comes down to how HP encodes the battery data and how it is accessed and not a hardware fault, but a quirk with HP.''***
      Étapes du tutoriel
      Étape 1 — Enregistrer les données de calibrage d'origine
      Cette batterie est trop vieille pour un recalibrage.
      Étape 2 — Utiliser votre ordinateur portable
      Toutes les données de cette étape seront perdues. Ne branchez l'ordinateur portable que pour démarrer la machine à partir d'un BIOS éteint.
      Étape 3 — Brancher votre ordinateur portable
      Bien que l'utilisation de votre ordinateur portable ne pose pas de problème en soi, la précision du calibrage peut être affectée.
      Étape 4 — Vérifier les nouvelles données d'étalonnage
      Cette procédure peut "tuer" une batterie en fin de vie.
      Étape 5 — (Windows 10) Vérification de l'état de la batterie
      Cela peut ne pas fonctionner si votre batterie est plus ancienne, même si c'est une pièce OEM.
      Étape 6 — (HP UEFI) Contournement de l'extinction à 15%
      Ceci va décharger la batterie complètement. Les autotests HP ne vérifient pas la capacité de charge.
      Étape 7 — (HP Legacy BIOS) Contournement de l'extinction à 15%
      N'APPLIQUEZ PAS ces réglages à votre système d'exploitation (OS) primaire. Ils risquent d'endommager la batterie.
      Étape 8 — (Lenovo 0190) Contournement d'une batterie critiquement faible
      Branchez l'adaptateur à votre ordinateur portable. Laissez le POST se terminer avant de débrancher l'ordinateur portable.
      Étape 9 — (Facultatif) Classer l'état de la batterie
      Pour mieux suivre l'état de santé estimé de la batterie, il est recommandé de prendre note de l'état final de la batterie.
      Étape 10
      Étape 11
