Aller au contenu principal
Starbucks Barista Teardown
Anglais
Français
Traduction de l’étape 4
Étape 4
Starbucks Barista Teardown: étape 0, image 1 de 3 Starbucks Barista Teardown: étape 0, image 2 de 3 Starbucks Barista Teardown: étape 0, image 3 de 3
  • Use a wrench to remove the boiler hose from the pressure release valve.
  • Remove the two slotted screws securing the pump brackets to the frame of the Barista.
  • The simple angled rubber pump brackets are designed to absorb vibration from the reciprocating pump.
  • Disconnect the two female AC power spade connectors from the pump and slip the thermal fuse out from its holder on the body of the pump.
  • The thermal fuse is a normally closed protective switch that opens the circuit once the pump has reached a critical temperature, thus shutting it down before the coil melts.
Insérez ici votre traduction
