Traduction de l’étape 2
Étape 2
Use an opening pick to pry up the battery from the bottom using firm, constant pressure.
- | [* black] Use an opening pick to pry the battery from the bottom. |
+ | [* black] Use an opening pick to pry up the battery from the bottom using firm, constant pressure. |
[* icon_caution] You will be prying against the case directly above the daughterboard and antenna cables. Pry carefully to avoid damaging either of these components. | |
[* icon_note] You may need to reheat and reapply the iOpener repeatedly to further soften to adhesive. The adhesive is tough and it may take a few tries to get the pick started under the battery. | |
[* icon_caution] Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools. |
