Aller au contenu principal
Remplacement de la batterie du Samsung Galaxy S7 Edge
Anglais
Français
Traduction de l’étape 4
Étape 4
Samsung Galaxy S7 Edge Battery Replacement: étape 0, image 1 de 2 Samsung Galaxy S7 Edge Battery Replacement: étape 0, image 2 de 2
  • Lift the battery out of the case.
  • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
  • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
  • To install a new battery and adhesive, follow this guide.
Soulevez la batterie hors de la coque.
Ne réutilisez pas la batterie après l'avoir retirée, vous mettriez votre sécurité en danger. Remplacez-la par une batterie neuve.
Pour monter une nouvelle batterie et ses bandes adhésives, suivez ce tutoriel.
[* black] Lift the battery out of the case.
-[* icon_caution] Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
+ [* icon_caution] Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
+[* black] If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
[* icon_reminder] To install a new battery and adhesive, [guide|123541|follow this guide.|new_window=true]
