Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 21 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Apply heat to the left edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably. If necessary, re-heat your iOpener for a few seconds or until it's a bit too hot to touch. Be careful not to overheat the iOpener, or it may burst. Insert a second opening pick at the bottom left corner of the iPad.
Slice through the left adhesive
  • Apply heat to the left edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
  • If necessary, re-heat your iOpener for a few seconds or until it's a bit too hot to touch. Be careful not to overheat the iOpener, or it may burst.
  • Insert a second opening pick at the bottom left corner of the iPad.
  • Slide the second opening pick along the left side of the display to separate the adhesive underneath.
  • Leave the opening pick inserted near the top left corner of the iPad to prevent the adhesive from re-sealing.
Chauffez le bord gauche de l'iPad pendant deux minutes, ou moins, si l'écran devient trop chaud et que vous ne pouvez plus le toucher sans vous brûlez.
Si nécessaire, réchauffez votre iOpener quelques secondes. Faites attention à ne pas trop chauffer l'iOpener, il risquerait d'éclater.
Insérez un autre médiator dans le coin inférieur gauche.
Faites glisser le médiator le long du côté gauche afin de décoller l'adhésif.
Laissez le médiator en place dans le coin supérieur gauche afin d'éviter que l'adhésif colle à nouveau.
+[title] Slice through the left adhesive
[* black] Apply heat to the left edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
[* black] If necessary, re-heat your iOpener for a few seconds or until it's a bit too hot to touch. Be careful not to overheat the iOpener, or it may burst.
[* black] Insert a second opening pick at the bottom left corner of the iPad.
[* black] Slide the second opening pick along the left side of the display to separate the adhesive underneath.
[* black] Leave the opening pick inserted near the top left corner of the iPad to prevent the adhesive from re-sealing.
