Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 21 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 11
Étape 11
These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery. Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery. Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
Battery connector information
  • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
  • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
Ces photos montrent à quoi ressemble le connecteur de la batterie sous la carte mère. Utilisez ces photos comme référence pendant que vous débranchez la batterie en toute sécurité.
Remarquez que le connecteur de la batterie comporte des ressorts en porte-à-faux sur la carte mère. qui appuient sur les plots de contact de la batterie. Comme la carte mère et la batterie sont collées, vous devrez glisser un objet fin et flexible entre les points de contact pour déconnecter la batterie.
