Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 10 tutoriels qui comprennent cette étape.
Traduction de l’étape 4
Prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick. This will angle the phone so that the opening tool is easier to insert.
Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
Press the edge of an opening tool into the gap.
