Aller au contenu principal
Remplacement de la batterie du Samsung Galaxy S10e
Anglais
Français
Traduction de l’étape 1
Étape 1
Samsung Galaxy S10e Battery Replacement: étape 0, image 1 de 2 Samsung Galaxy S10e Battery Replacement: étape 0, image 2 de 2
  • This step can be completed using either adhesive remover or high concentration (over 90%) isopropyl alcohol.
  • Prop the bottom edge of the phone up to angle the phone so that the adhesive remover will run from the bottom of the battery toward the top.
  • Apply 1-2 drops of isopropyl alcohol or adhesive remover along the bottom edge of the battery. Allow it to sit for several minutes to allow the adhesive to weaken.
  • Using too much alcohol or adhesive remover can damage the display.
Vous pouvez utiliser du dissolvant pour adhésif ou de l'alcool isopropylique à haute concentration (plus de 90 %) pour cette étape.
Surélevez le bord inférieur du téléphone pour l'incliner de façon que le dissolvant coule de bas en haut sous la batterie.
Appliquez l'alcool isopropylique ou le dissolvant pour adhésif le long du bord inférieur de la batterie. Laissez agir quelques minutes pour que l'adhésif ait le temps de ramollir.
[* icon_note] This step can be completed using either [product|IF145-400-4|adhesive remover|new_window=true] or high concentration (over 90%) isopropyl alcohol.
[* black] [https://d3nevzfk7ii3be.cloudfront.net/igi/3keq4Gc6yo3VSFEN.full|Prop the bottom edge of the phone up|new_window=true] to angle the phone so that the adhesive remover will run from the bottom of the battery toward the top.
-[* black] Apply isopropyl alcohol or adhesive remover along the bottom edge of the battery. Allow it to sit for several minutes to allow the adhesive to weaken.
+[* black] Apply 1-2 drops of isopropyl alcohol or adhesive remover along the bottom edge of the battery. Allow it to sit for several minutes to allow the adhesive to weaken.
+ [* icon_caution] Using too much alcohol or adhesive remover can damage the display.
