Traduction de l’étape 6
Étape 6
Despite their similar hardware, iPads continue to lag way, way behind iPhones in their construction—this home button being a perfect example. On iPhones this is an easy, elegant swap, but here it's still a mess of glue, even after all this time.
Elsewhere on this display, we blast the shields off and smoke out the chips underneath:
Parade Technologies DP815 Display Port timing controller (likely)
Texas Instruments TPS65195 clock level shifter
Texas Instruments TPS65144 LCD Bias w/ integrated gamma reference
Intersil ISL24879 precision programmable LCD reference voltage generator
STMicroelectronics M24C64-F 64 Kb Serial EEPROM memory
[* black] Despite their similar hardware, iPads continue to lag way, way behind iPhones in their construction—this home button being a perfect example. On iPhones this is [guide|100950|an easy, elegant swap|stepid=189484|new_window=true], but here it's still a mess of glue, [guide|30628|even after|stepid=71873|new_window=true] [guide|48891|all this time|stepid=107324|new_window=true]. | |
[* black] Elsewhere on this display, we blast the shields off and smoke out the chips underneath: | |
- | [* red] Parade DP815 (likely a timing controller) |
- | [* orange] Texas Instruments [https://datasheet.octopart.com/TPS65195YFFR-Texas-Instruments-datasheet-15994572.pdf|TPS65195|new_window=true] level shifters |
- | [* yellow] Texas Instruments TPS65144 LCD bias |
- | [* green] 24879 B834QL |
+ | [* red] Parade Technologies DP815 Display Port timing controller (likely) |
+ | [* orange] Texas Instruments [https://datasheet.octopart.com/TPS65195YFFR-Texas-Instruments-datasheet-15994572.pdf|TPS65195|new_window=true] clock level shifter |
+ | [* yellow] Texas Instruments TPS65144 LCD Bias w/ integrated gamma reference |
+ | [* green] Intersil ISL24879 precision programmable LCD reference voltage generator |
+ | [* light_blue] STMicroelectronics [link|https://www.st.com/en/memories/m24c64-f.html|M24C64-F] 64 Kb Serial EEPROM memory |
