Traduction de l’étape 2
Étape 2
Turn the phone over and orient it so the bottom faces you.
Use tweezers to carefully lift the bottom cover held by glue.
Once you pry the bottom enough, gently pull the bottom away using your hands.
[* black] Turn the phone over and orient it so the bottom faces you. | |
- | [* black] Use tweezers to carefully lift the bottom cover held by glue. |
+ | [* black] Use [product|IF145-020|tweezers] to carefully lift the bottom cover held by glue. |
[* black] Once you pry the bottom enough, gently pull the bottom away using your hands. |
