Aller au contenu principal
Depth Sensor Node Enclosure Assembly
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 20
Étape 20
Depth Sensor Node Enclosure Assembly, Securing the Solar Panel Wire: étape 0, image 1 de 3 Depth Sensor Node Enclosure Assembly, Securing the Solar Panel Wire: étape 0, image 2 de 3 Depth Sensor Node Enclosure Assembly, Securing the Solar Panel Wire: étape 0, image 3 de 3
  • Fold wire over itself so that the portion above the hose clamp won't have slack when the black wire section is pressed against the inside of the panel
  • Obtain a hose clamp, and secure the red part of the wire to the black section using a drill fitted with the drill bit
  • Wrap a zip tie around the wire as shown.
  • Use a second zip tie to connect the ends of the first one
Insérez ici votre traduction
