Aller au contenu principal
Remplacement de la batterie de l'iPhone 11
Anglais
Français
Traduction de l’étape 9
Étape 9
iPhone 11 Battery Replacement, Removing a stuck battery (alternate method): étape 0, image 1 de 3 iPhone 11 Battery Replacement, Removing a stuck battery (alternate method): étape 0, image 2 de 3 iPhone 11 Battery Replacement, Removing a stuck battery (alternate method): étape 0, image 3 de 3
  • If your battery is stuck and an appropriate liquid solvent is not available, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
  • Heat the iPhone until the rear case is slightly too hot to comfortably touch, but no more.
  • Flip the iPhone back over and thread a strong piece of string (such as dental floss) underneath the battery.
  • Wear gloves to protect your fingers, or wrap each end of the string around a tool.
  • Pull the string from side to side in a sawing motion to separate the adhesive. This can take some time since the adhesive is slow to deform, but with patience it will come free. Do not deform or damage the battery.
  • Start from the top or bottom edge of the battery, and pull toward the middle. Don't pull the string through the middle third of the battery, or you may damage the ribbon cables or the wireless charging coil directly underneath.
  • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
Si votre batterie est collée et que vous n'avez pas de dissolvant approprié sous la main, préparez un iOpener ou servez-vous d'un sèche-cheveux pour chauffer la coque arrière, au niveau de la batterie.
Faites chauffer l'iPhone jusqu'à ce que la coque arrière soit légèrement trop chaude au toucher, mais pas plus.
Retournez l'iPhone et faites passer une ficelle solide (par exemple du fil dentaire) sous la batterie.
Portez des gants ou enroulez le bout de la ficelle autour d'un outil pour protéger vos doigts.
Tirez la ficelle d'un bout à l'autre comme si vous sciez l'adhésif pour le décoller. Cela pourra prendre du temps si l'adhésif ne se déforme pas facilement, mais avec de la patience, vous y arriverez. Ne déformez ni endommagez la batterie.
Commencez en bas ou en haut de la batterie, et progressez vers le milieu. Ne faites pas passer votre ficelle sous le tiers central de la batterie, vous risqueriez d'endommager les nappes et la bobine de charge sans fil, qui se trouvent juste en dessous.
Si vous décidez d'utiliser des outils à levier pour soulever la batterie hors de l'iPhone, faites extrêmement attention ! Vous risquez d'endommager les nappes et la bobine de charge sans fil, nommées ci-dessus.
