Aller au contenu principal
Remplacement de l'objectif du Canon Powershot Pro1
Anglais
Français
Traduction de l’étape 3
Étape 3
Canon Powershot Pro1 Lens Replacement: étape 0, image 1 de 3 Canon Powershot Pro1 Lens Replacement: étape 0, image 2 de 3 Canon Powershot Pro1 Lens Replacement: étape 0, image 3 de 3
  • Place the camera on its back with the lens facing upwards as shown in the image
  • Remove the additional 1.5 mm Phillip #1 screw from underneath the lens cover
  • Remove the screw by turning the Philip driver counterclockwise.
  • By removing the screw, you will be able to remove the cover lens.
Retirez le cache de l'objectif.
Retirez les vis cruciformes n ° 1 supplémentaires de 1,5 mm sous le couvercle de l'objectif.
-[* black] Remove the lens cover.
-[* black] Remove the additional 1.5 mm Phillips #1 screws from underneath the lens cover.
+[* black] Place the camera on its back with the lens facing upwards as shown in the image
+[* black] Remove the additional 1.5 mm Phillip #1 screw from underneath the lens cover
+[* black] Remove the screw by turning the Philip driver counterclockwise.
+[* black] By removing the screw, you will be able to remove the cover lens.
