Aller au contenu principal
Toshiba Satellite L55W-C5256 CPU Heatsink Replacement
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: étape 0, image 1 de 3 Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: étape 0, image 2 de 3 Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: étape 0, image 3 de 3
  • Before you touch any component inside your device, ensure you are properly grounded with an anti-static band.
  • Gently lift the heat sink from the motherboard, making sure not to apply much tension to the connector cable.
  • Using your thumb and forefinger, gently unplug the connector cable from the motherboard.
  • Lift the heat sink from the motherboard.
  • If you need to replace the heat sink, check out this thermal paste guide that will walk you through the steps necessary to replace the thermal compound.
Insérez ici votre traduction
