Aller au contenu principal
Retirer le panneau frontal de l'iPad 3 4G
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 153 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 13
Étape 13
Removing iPad 3 4G Front Panel: étape 0, image 1 de 2 Removing iPad 3 4G Front Panel: étape 0, image 2 de 2
  • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
  • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
  • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
Pendant cette étape, vous devez faire glisser le médiator le long du bord inférieur droit du panneau frontal. L'antenne Wi-Fi est très proche du coin et se coupe facilement, si l'adhésif est décollé de façon incorrecte.
Ne retirez pas complètement le médiator sous la vitre tactile, mais seulement jusqu'à ce que environ 1/8ème de sa pointe reste en dessous de la vitre tactile.
Faites glisser la pointe du médiator le long du bord inférieur de l'iPad pour décoller l'adhésif de l'antenne Wi-Fi.
[* icon_caution] This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
-[* icon_note] Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" of the tip is still under the front glass.
+[* icon_note] Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
[* black] Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
