Aller au contenu principal
Remplacement de la batterie du MacBook Pro 13" deux ports Thunderbolt 2019
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 17
Étape 17
MacBook Pro 13" Two Thunderbolt Ports 2019 Battery Replacement: étape 0, image 1 de 2 MacBook Pro 13" Two Thunderbolt Ports 2019 Battery Replacement: étape 0, image 2 de 2
  • Lift and remove the battery.
  • Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
  • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
  • Otherwise, soak each strip of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with a plastic tool. This can take quite a bit of work, so be patient.
  • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
  • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
  • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
  • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
Soulevez et ôtez la batterie.
Avant d'installer votre nouvelle batterie, ôtez tous les résidus d'adhésif du boîtier du MacBook Pro.
Avec un peu de chance, il suffit de tirer lentement sur chaque bande d'adhésif avec vos doigts.
Sinon, recouvrez chaque bande avec du dissolvant pour adhésif et laissez agir 2 à 3 minutes. Puis grattez avec un outil en plastique. Cela peut prendre du temps, soyez donc patient. Épongez ensuite les restes de dissolvant pour adhésif et laissez votre MacBook Pro sécher pendant quelques miutes.
La batterie de remplacement incluse dans votre kit iFixit est déjà munie d'adhésif. Vérifiez que la batterie correspond en taille et alignement avant de décoller le film de protection de l'adhésif. Posez les cellules et appuyez fermement sur chacune. S'il reste d'autres films qui n'étaient pas sur votre batterie d'origine, retirez-les maintenant.
Calibrez votre nouvelle batterie :
Chargez-la à 100%, puis laissez charger encore au moins deux heures. Utilisez votre appareil normalement. Lors de l'avertissement de batterie faible, enregistrez votre travail et laissez votre ordinateur allumé jusqu'à ce que la batterie soit vide et qu'il s'éteigne. Attendez au moins 5 heures, puis rechargez la batterie à 100% sans interruption.
Si vous remarquez quelques chose d'inhabituel ou si vous avez des problèmes après l'installation de la nouvelle batterie, il se peut que vous deviez réinitialiser le SMC de votre MacBook Pro.
