Aller au contenu principal
Autosampler Battery and Node Enclosure Assembly (2021)
Anglais
Français
Traduction de l’étape 12
Étape 12
Autosampler Battery and Node Enclosure Assembly (2021), Attach the Wires from the 6-pin Connector to the Board: étape 0, image 1 de 3 Autosampler Battery and Node Enclosure Assembly (2021), Attach the Wires from the 6-pin Connector to the Board: étape 0, image 2 de 3 Autosampler Battery and Node Enclosure Assembly (2021), Attach the Wires from the 6-pin Connector to the Board: étape 0, image 3 de 3
  • Attach the blue, green, and brown wires from the 6-pin connector to the board. These wires have been fed through the box previously and are heat shrink wrapped.
  • Screw the green wire into the topmost terminal on the top connector.
  • Screw the blue wire into the terminal directly below the green wire
  • Screw the brown wire into the terminal directly below the black wire on the top connector.
Insérez ici votre traduction
