Aller au contenu principal
Autosampler Battery and Node Enclosure Assembly (2021)
Anglais
Français
Traduction de l’étape 5
Étape 5
Autosampler Battery and Node Enclosure Assembly (2021), Separate Sampler Wires: étape 0, image 1 de 3 Autosampler Battery and Node Enclosure Assembly (2021), Separate Sampler Wires: étape 0, image 2 de 3 Autosampler Battery and Node Enclosure Assembly (2021), Separate Sampler Wires: étape 0, image 3 de 3
  • Pull the power(black) and ground(white) wires separate from the signal wires(all others).
  • Cut the black casing down as done earlier to expose the wires for testing until the wires can reach through the entire node box.
  • Feed the two groups of wires for signaling and for power through two separate sheaths of heat shrink wrap.
  • Cover the joint with a larger section of heat shrink cable.
Insérez ici votre traduction
