Aller au contenu principal
Remplacement de la batterie de l'iPhone 13 Pro Max
Anglais
Français
Conditions préalables au tutoriel
Tous les tutoriels prérequis doivent être traduits avant que cette traduction soit considérée comme complète.
Remplacement des vis Pentalobe de l'iPhone 13 Pro Max
Repère de profondeur sur un médiator (prérequis)
Retrait de l'écran
Retrait du haut-parleur
Remplacement du Taptic Engine de l'iPhone 13 Pro Max
Informations sur le tutoriel
= Terminé = Incomplet
    Follow this guide to replace the battery on an iPhone 13 Pro Max.
    If your battery is swollen, [[What to do with a swollen battery|take appropriate precautions|new_window=true]].
    ***Note***: After the repairOn iOS 17.6 and earlier, your iPhone may display a warning about the “genuineness” of the battery after the repair, even when using original Apple parts. If your iPhone functions normally, you can safely ignore the warning. On iOS 18 and newer, authenticate your new battery using Apple's [link|https://support.apple.com/en-us/120579|Repair Assistant|new_window=true].
    For optimal performance, after completing this guide, [[Battery Calibration|calibrate]] your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
      ***To reassemble your device, follow the above steps in reverse order.***
      After your repair, depending on the replacement part, you may be able to [link|https://support.apple.com/en-us/120579|calibrate it using Apple's Repair Assistant|new_window=true], available as of iOS 18. Update your device, navigate to Settings ***→*** General ***→***About ***→*** Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
      Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
      Repair didn’t go as planned? Try some [[Troubleshooting Problems After a Repair|basic troubleshooting]], or ask our iPhone 13 Pro Max [link|https://www.ifixit.com/Answers/Device/iPhone%2013%20Pro%20Max|Answers community] for help.
      Étapes du tutoriel
      Étape 1 — Repérer les bandes adhésives d'extraction
      La batterie est fixée à la coque arrière par quatre bandes adhésives étirables : deux en bas et deux en haut.
      Étape 2 — Décoller les bandes adhésives étirables
      Prenez une pincette arrondie pour décoller les deux languettes d'extraction en bas de la batterie.
      Étape 3
      Saisissez la première languette d'extraction avec vos doigts ou enroulez-la au milieu d'une spatule et éloignez-la lentement de la batterie, en direction du bas de l'iPhone.
      Étape 4
      Saisissez la deuxième languette et éloignez-la de la batterie, en la tirant vers le bas de l'iPhone.
      Étape 5
      Prenez une pincette arrondie et un médiator pour décoller les deux dernières languettes d'extraction en haut de la batterie.
      Étape 6
      Suivez la même procédure que tout à l'heure. Tirez sur les deux languettes restantes, une à la fois, pour étirer et décoller l'adhésif qui fixe la batterie. Veillez à ce que les bandes ne restent accrochées nulle part.
      Étape 7 — Comment enlever une batterie récalcitrante
      Si vous avez encore du mal à retirer la batterie, appliquez quelques gouttes d'alcool isopropylique à haute concentration (plus de 90 %) sous le bord de la batterie, là où la ou les bandes adhésives se sont déchirées.
      Étape 8 — Ôter la batterie
      Enlevez la batterie.
