Aller au contenu principal
Changement écran iPhone 14 Pro Max
Anglais
Français
Conditions préalables au tutoriel
Tous les tutoriels prérequis doivent être traduits avant que cette traduction soit considérée comme complète.
Changement vis Pentalobe iPhone 14 Pro
Repère de profondeur sur un médiator (prérequis)
Écran iPhone 14 Pro (prérequis)
Informations sur le tutoriel
= Terminé = Incomplet
    If your iPhone 14 Pro screen is cracked, not responding to touch, or not showing a picture when your phone is powered on, use this guide to restore your iPhone to working order with a new screen, a.k.a. display assembly.
    This guide was created using the ***A2890*** (international) model. If you're fixing a different iPhone 14 Pro model, there may be some visual discrepancies, but the procedure should be the same.
    ***For your safety, discharge the battery below 25% before disassembling your device.*** This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, [[What to do with a swollen battery|take appropriate precautions|new_window=true]].
    ***Note:***: On iOS 17.6 and earlier, True Tone and auto brightness functionality areis disabled after a screen replacement, even when using an original Apple screen. Face ID is also disabled, unless the iPhone runsis running iOS 15.2 or newer. On iOS 18 and newer, you can calibrate your new screen using Apple's [link|https://support.apple.com/en-us/120579|Repair Assistant|new_window=true] to restore True Tone functionality on genuine screens purchased from Apple.
    You’ll need replacement adhesive to reattachsafely secure the screen when reassembling your iPhone. Retaining water resistance after the device. Yourrepair will depend on how well you reapply the screen adhesive, but note that your device will function normally, but will most likely lose its official IP ([link|https://www.iec.ch/ip-ratings#:~:text=Electric%20and%20electronic%20equipment%20deteriorate,are%20widely%20used%20throughout%20industry.|Ingress Protection|new_window=true]) rating.
      If possible, turn on your device and test your repair before installing new adhesive and resealing.
      ***To reassemble your device, follow these instructions in reverse order.***
      After your repair, depending on the replacement part, you may be able to [link|https://support.apple.com/en-us/120579|calibrate it using Apple's Repair Assistant|new_window=true], available as of iOS 18. Update your device, navigate to Settings ***→*** General ***→***About ***→*** Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
      The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the frame and place the screen back in its original position.
      Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
      Repair didn’t go as planned? Try some [[Troubleshooting Problems After a Repair|basic troubleshooting]], or ask our [link|https://www.ifixit.com/Answers/Ask/iPhone+14+Pro|Answers community] for help.
      Étapes du tutoriel
      Étape 1 — Détacher le cache des capteurs frontaux
      Les étapes suivantes montrent comment transférer le module capteurs frontaux sur un nouvel écran. Si votre écran de rechange est déjà muni d'un ensemble, sautez cette étape.
      Étape 2 — Retirer le cache des capteurs frontaux
      Avec une pincette ou vos doigts, enlevez le cache des capteurs frontaux.
      Étape 3 — Faire chauffer le module capteurs frontaux
      Faites chauffer un iOpener et posez-le sur le bord supérieur de l'écran pendant deux minutes.
      Étape 4 — Déconnecter le capteur de proximité
      Insérez un médiator entre le capteur de proximité et son logement dans l'écran.
      Étape 5 — Débrancher le capteur de luminosité ambiante
      Insérez un médiator entre le capteur de luminosité ambiante et son logement dans l'écran.
      Étape 6 — Retirer le module capteurs frontaux
      Il est possible que l'adhésif ait refroidi à présent. Si c'est le cas, posez un iOpener chauffé sur le module pendant une minute avant de continuer.
      Étape 7
      Ôtez le module capteurs frontaux.
