Aller au contenu principal
Changement caméra arrière iPhone 14 Pro Max
Anglais
Français
Conditions préalables au tutoriel
Tous les tutoriels prérequis doivent être traduits avant que cette traduction soit considérée comme complète.
Changement vis Pentalobe iPhone 14 Pro Max
Repère de profondeur sur un médiator (prérequis)
Prérequis écran iPhone 14 Pro Max
Informations sur le tutoriel
= Terminé = Incomplet
    Use this guide to replace the rear-facing camera assembly in your iPhone 14 Pro Max.
    This guide was created using the ***A2894*** (international) model. If you're fixing a different iPhone 14 Pro Max model, there may be some visual discrepancies, but the procedure should be the same.
    ***Note***: On iOS 18 and newer, you can calibrate new, genuine camera modules using Apple's [link|https://support.apple.com/en-us/120579|Repair Assistant|new_window=true].
    You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
      If possible, turn on your device and test your repair before installing new adhesive and resealing.
      ***To reassemble your device, follow these instructions in reverse order.***
      After your repair, depending on the replacement part, you may be able to [link|https://support.apple.com/en-us/120579|calibrate it using Apple's Repair Assistant|new_window=true], available as of iOS 18. Update your device, navigate to Settings ***→*** General ***→***About ***→*** Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
      Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
      Repair didn’t go as planned? Try some [[Troubleshooting Problems After a Repair|basic troubleshooting]], or ask our [link|https://www.ifixit.com/Answers/Ask/iPhone+14+Pro+Max|Answers community] for help.
      Étapes du tutoriel
      Étape 1 — Dévisser les vis du cache de la caméra arrière
      Utilisez un tournevis Y000 pour retirer les cinq vis qui fixent le cache de l'ensemble caméra arrière :
      Étape 2 — Retirer le cache de l'ensemble caméra arrière
      Le coin supérieur droit du cache de la caméra dispose d'un petit bord métallique, qui est encastré dans le châssis du téléphone.
      Étape 3 — Déconnecter la nappe de la caméra ultra grand-angle et du téléobjectif
      Utilisez une spatule pour déconnecter la nappe de la caméra ultra grand-angle et du téléobjectif, en faisant levier sur le connecteur pour le soulever tout droit hors de sa prise.
      Étape 4 — Déconnecter la nappe de la caméra ultra grand-angle
      Utilisez une spatule pour déconnecter la nappe de la caméra ultra grand-angle, en faisant levier sur le connecteur pour le soulever tout droit hors de sa prise.
      Étape 5 — Soulever l'ensemble caméra arrière
      Insérez la pointe d'une spatule sous le bord inférieur de l'ensemble caméra arrière.
      Étape 6 — Retirer l'ensemble caméra arrière
      Ôtez l'ensemble caméra arrière à l'aide d'une pincette ou de vos doigts.
