Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 43 tutoriels qui comprennent cette étape.
Traduction de l’étape 24
Étape 24
If there is a wire or cable underneath adhesive tape, always pull the tape off first.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
