Aller au contenu principal
Pixel 8 Pro Graphite Sheet Removal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Pixel 8 Pro Graphite Sheet Removal, Remove the graphite tape: étape 0, image 1 de 3 Pixel 8 Pro Graphite Sheet Removal, Remove the graphite tape: étape 0, image 2 de 3 Pixel 8 Pro Graphite Sheet Removal, Remove the graphite tape: étape 0, image 3 de 3
  • A large graphite sheet must be removed and replaced to complete this repair. It connects the upper part of the battery, midframe, and the rear cameras.
  • Insert the point of a spudger under different parts of the graphite sheet and lift until you can grip the sheet with your fingers.
  • The sections of graphite sheet between the rear cameras and the battery will most likely tear. If they do, grip the broken part of the sheet and remove that section.
  • Peel up and remove the entire graphite sheet.
  • During reassembly, do not reuse the old graphite sheet. Follow this guide to replace the sheet.
Insérez ici votre traduction
