Aller au contenu principal
Pixel 8 Pro Pixel 8 Pro Antenna Cable Disconnect
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Pixel 8 Pro Pixel 8 Pro Antenna Cable Disconnect, Disconnect the antenna cable: étape 0, image 1 de 3 Pixel 8 Pro Pixel 8 Pro Antenna Cable Disconnect, Disconnect the antenna cable: étape 0, image 2 de 3 Pixel 8 Pro Pixel 8 Pro Antenna Cable Disconnect, Disconnect the antenna cable: étape 0, image 3 de 3
  • Insert one arm of a pair of angled tweezers under the metal neck of the black antenna cable coaxial connector, located on the top left corner of the logic board.
  • Gently lift straight up to disconnect the cable.
  • To reconnect the cable, hold the connector in place over its socket and press down with the flat end of a spudger—the connector should snap into place. If you're having trouble, don't try to force the connector over the socket. Reposition it and try again.
Insérez ici votre traduction
