Aller au contenu principal
Meta Quest 2 Screen and Lens Assembly Replacement
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 9
Étape 9
Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: étape 0, image 1 de 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: étape 0, image 2 de 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: étape 0, image 3 de 3
Reassembly note
  • During reassembly, be careful not to trap the twelve cables as you insert the lens assembly into the outer shell:
  • Three cables along the top edge—two flex cables and one LED flex cable
  • Two cables in the top right corner—the battery connector and an antenna cable
  • Two cables along the right edge—an antenna cable and a wide flex cable
  • Two flex cables along the bottom edge
  • Three cables along the left edge—one antenna cable, one flex cable, and one speaker cable
  • You can use a rubber band to help secure the cables out of the way.
Insérez ici votre traduction
