Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 13 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the following three screws securing the right speaker to the upper case: One 5.6 mm T5 Torx screw
  • Remove the following three screws securing the right speaker to the upper case:
  • One 5.6 mm T5 Torx screw
  • One 6.9 mm T5 Torx screw
  • One 2.6 mm T5 Torx screw
  • Remove the right speaker from the MacBook Pro.
  • The speaker is secured to the case with some light adhesive.
Retirez les trois vis suivantes fixant le haut-parleur droit au boîtier supérieur :
Une vis Torx T5 de 5,6 mm
Une vis Torx T5 de 6,9 mm
Une vis Torx T5 de 2,6 mm
Retirez le haut-parleur droit du MacBook Pro.
[* black] Remove the following three screws securing the right speaker to the upper case:
[* red] One 5.6 mm T5 Torx screw
[* orange] One 6.9 mm T5 Torx screw
[* yellow] One 2.6 mm T5 Torx screw
[* black] Remove the right speaker from the MacBook Pro.
+ [* icon_note] The speaker is secured to the case with some light adhesive.
