Aller au contenu principal
PS4 Case Opening Procedure for Cleaning
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 5
Étape 5
PS4 Case Opening Procedure for Cleaning, Disconnect the power supply: étape 0, image 1 de 2 PS4 Case Opening Procedure for Cleaning, Disconnect the power supply: étape 0, image 2 de 2
  • Use a pair of tweezers to pull the power supply cable straight out to disconnect the power supply unit from the motherboard.
  • Depending on the age of your console, this cable might be very firmly connected. If it feels stuck, don't pull on the cables themselves with much force.
  • Use your fingers to grab the white connector head, and wiggle or "walk" the connector out of its socket to disconnect it.
  • In extreme cases, you might need to use needle nose pliers to get a good grip on the connector.
  • Go slow: pulling on the cables themselves might rip them out of the connector.
Insérez ici votre traduction
