Aller au contenu principal
Pentax Spotmatic Front Lens Board Removal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Pentax Spotmatic Front Lens Board Removal, Remove front lens board: étape 0, image 1 de 3 Pentax Spotmatic Front Lens Board Removal, Remove front lens board: étape 0, image 2 de 3 Pentax Spotmatic Front Lens Board Removal, Remove front lens board: étape 0, image 3 de 3
  • Remove four 4.6 mm flat head screws.
  • Remove one 4.3 mm flat head screws.
  • Lift off front lens board.
  • Note the position and number of shim washers at each screw location. They need to be installed in the same positions during reassembly.
  • If the top cover is still attached, lift the bottom of the lens board first. There is a lip around the top of the lens mount that engages with the top.
Insérez ici votre traduction
