Traduction de l’étape 25
Étape 25
Remove Barrel Lip
The rear end of the barrel assembly has a metal cap
Using PH00 Screwdriver remove the 4 screws
Use a flat blade screwdriver to carefully lift the cap at multiple points around the circumference. It is a tight fit.
Be careful when removing it, as there is a plastic spacer underneath.
