Aller au contenu principal
Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair
Ce dont vous avez besoin
Vidéo d'introduction
    • Before starting this guide be sure to assess that the lenses fault matches these symptoms. If your symptoms are different, this guide may still help with disassembly for repairing other faults.
    • Symptoms
    • When focussing the camera may shut off with 'Error 00' message.
    • In manual focus mode the focus can not be adjusted, but the iFn ring does still work (e.g. for changing aperture).
    • Focus only works at some zoom levels.
    • At a zoom level where focus does work, the focus elements can be seen to move through the front element.
  1. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Extra Pictures of FPC: étape 2, image 1 de 2 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Extra Pictures of FPC: étape 2, image 2 de 2
    • Some pictures of the FPC from when there was still some stock available to buy
  2. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Preparation: étape 3, image 1 de 1
    • Detach lens from camera
    • Fit front cover to lens.
    • Fit sensor cover to camera.
    • Remove tripod attachment
    • Prepare a clean (dust free) area with ESD protection.
  3. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Loosen Electrical Contact Ring: étape 4, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Loosen Electrical Contact Ring: étape 4, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Loosen Electrical Contact Ring: étape 4, image 3 de 3
    • Using PH0 driver remove the 3 circumferential screws pointed to by the green arrows. Do not remove the 4 screws with the red crosses.
    • Screws: 3 @ M1.4 x 2.5mm Wafer head
  4. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Electrical Contact Retainer: étape 5, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Electrical Contact Retainer: étape 5, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Electrical Contact Retainer: étape 5, image 3 de 3
    • Using flat blade screw driver gently lift the retaining ring.
    • Work slowly and at multiple points around the circumference to lift the ring squarely.
  5. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Detach Electrical Contact Block: étape 6, image 1 de 2 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Detach Electrical Contact Block: étape 6, image 2 de 2
    • Using PH00 Screwdriver remove the two screws holding the contact block.
    • Use a pair of fine tweezers as you undo the screws to prevent them falling inside the lens
    • The contact block will now be loose, but held by its flex pcb.
    • Screws: 2@ M1.4 x 2.5mm wafer head (Black)
    • Bag and label removed parts as you go.
  6. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Mount Ring: étape 7, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Mount Ring: étape 7, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Mount Ring: étape 7, image 3 de 3
    • Using PH0 Screwdriver remove the 4 screws attaching the mount ring to the lens.
    • There is a small amount of threadlock on these screws.
    • Screws: 4@ M1.6 x 6 (white threadlock)
    • Carefully lift the mount ring. The lens sealing gasket may have adhered to it and lift as well. This is ok.
    • Remove the lens sealing gasket, and two metal shims.
    • Note the profile on the gasket. The longer bevelled edge faces outwards.
    • The metal shims are identical so can be replaced in any order.
    • Note the plastic pillars to align the parts.
  7. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Conical Body Section: étape 8, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Conical Body Section: étape 8, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Conical Body Section: étape 8, image 3 de 3
    • Using PH0 Screwdriver remove the three screws circled in green.
    • Do not remove the 3 screws with red crosses.
    • Screws: 3@ M1.6 x 4 wafer head (white threadlock)
    • There is a rubber gasket under the conical section. Note the profile has the round surface fitting into the conical section, and the double wiper section pressing into the foam gasket on the body.
  8. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Disconnect PCB: étape 9, image 1 de 2 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Disconnect PCB: étape 9, image 2 de 2
    • Insert the finest tip flat blade screwdriver between the tab on the ribbon cables and the white connectors, and gently pry the 6 FPCs out.
    • Markings on the contact block FPC are: XL1103_CONTAC_FPCB-PV2-110701, FC1441, 1-18
    • Where FPC are installed contacts down there are two white lines on the FPC reinforcer showing the correct insertion level. One line inside connector and other other just outside.
    • Be Gentle with the FPC ribbons.
  9. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove PCB: étape 10, image 1 de 2 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove PCB: étape 10, image 2 de 2
    • Using a PH0 Screwdriver unfasten the 3 screws holding the PCB. Turn each screw alternately a little at a time to avoid warping the PCB as it rises.
    • Note the rubber isolating bushings and how the PCB slits into them.
    • The rubber bushing will come off with the screws
    • Note the 'C' shape of the PCB allows it to slide out horizontally. Take care to avoid catching the FPCs.
    • Place the PCB in an ESD safe bag
    • PCB Markings: XL1406 MAIN Rev05
  10. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Landscape-Portrait Ring: étape 11, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Landscape-Portrait Ring: étape 11, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Landscape-Portrait Ring: étape 11, image 3 de 3
    • Using a PH0 Screwdriver remove the three silver screws in the middle ring of screws.
    • Do not remove any of the 3 black screws in the recessed holes or the 3 silver screws nearest the back lens.
    • Lift the orientation ring. There are some felt pads on the lower lip that make it a little stiff, but it will lift out.
    • Note that one of the FPC is connected to the orientation ring.
    • Note that one of the plastic tabs has an orientation pillar that fits into the small hole near one of the screws.
    • Be very careful if you disassemble the orientation ring. There is a sping loaded detent roller that is difficult to re-fit.
    • Screws: 3@ M1.6 x 4mm (white threadlock)
    • FPC Marking: XL1406_FPC_ENCODER_FPC_Rev03 UFK144513
  11. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Zoom Ring - Outer: étape 12, image 1 de 2 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Zoom Ring - Outer: étape 12, image 2 de 2
    • Using a PH0 Screwdriver (you may need to use a PH00 if the shaft is too thick to fit) remove the 3 deeply recessed screws in the zoom ring.
    • When reassembling note the ridges on the zoom ring that fit into slots on the body. This is what transfers the torque from the ring to the body.
    • Screws: 3@ M1.4 x 3.5mm wafer head (black)
    • On this lens the rubber grip on the zoom ring was loose. Rotate the bodies zoom mechanism to the 50mm position (or 150mm), and then with the slots and ridges lined up, work out the correct position for the rubber grip by rotating it against the body. It appears to have been originally glued, but it can be repaired with some thin double sided tape.
    • Note that this lens has been apart once before. There was black tape securing the FPC ribbons which has been replaced with kapton (polyamide) tape.
    • The FPC Ribbons are double sided taped to the body
    • Note how the wide FPC ribbon that goes inside the metal body has been folded and taped together.
  12. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Zoom Ring - Inner: étape 14, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Zoom Ring - Inner: étape 14, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Zoom Ring - Inner: étape 14, image 3 de 3
    • Remove the 3 screws and nylon bushes running in tracks around the zoom zoom ring mechanism.
    • Note how the nylon bushes sit over studs in the body.
    • Not the 6 screws with bushes in the upper section.
    • Remove the recessed screw with the metal collar holding the zoom ring mechanism. This is the one that transfers torque to the internals.
    • As can be seen in this picture, the nylon bushes may be fractured, so be gentle.
    • Now that the plastic zoom ring is loose, rotate it until the metal studs on the body (that were holding the 3 screws and bushes) fit into gaps on the ring allowing it to be lifted off.
    • You may want to re-grease this on reassembly.
    • Screws: 3@ M1.6 x 3mm Wafer head (Black), + 1@ M1.6 x 4mm Wafer head (Silver)
  13. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, FPC Ribbon Detachment: étape 15, image 1 de 1
    • Remove the black tape (in these pictures it has already been replaced by polyamide/kapton tape).
    • Gently unpeel the FPC ribbon cables from the body.
    • The stepper motor under the black tape is for the aperture iris.
    • Note the iris cable doesn't need to be removed unless you are disassembling the iris/stabilisation module. There is a blob of glue under the connector on the iris FPC. Rather than trying to unplug the connector it can be carefully pried up.
    • FPC Marking: XL1406 Switch FPC Rev04 DREH13UM
    • FPC Marking: XL1406_IRIS_FPC_Rev03 UFK144512
  14. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Iris Section Removal: étape 16, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Iris Section Removal: étape 16, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Iris Section Removal: étape 16, image 3 de 3
    • Prepare a clean container for putting this once it has been removed
    • This section is the iris and optical stabilisation.
    • Using a PH0 ScrewDriver remove the 4 screws in the metal body (not the 3 screws in the plastic part)
    • Screws: 4@ M1.4 x 4mm Wafer head with threadlock
    • Lift the iris section off the body and place in clean box and seal.
  15. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, iFn Sleeve removal: étape 17, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, iFn Sleeve removal: étape 17, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, iFn Sleeve removal: étape 17, image 3 de 3
    • Using a PH0 Screwdriver remove the 3 silver screws holding the iFn sleeve onto the body. Do not separate yet.
    • Do NOT separate the two parts yet
    • Note the plastic shims that will come apart with this. The black one is inner (towards the front of the lens), and the clear one outer (towards camera).
    • Lie the lens on its side, and gently and gradually pull the front of the lens away from the body exposing a FPC Ribbon cable. Disconnect the cable from the connector and then finish separating the parts.
    • Screws: 3@ M1.4 x 4mm Wafer head (thread lock)
    • FPC Ribbon: XL1406_MF_PI_FPC_Rev04
    • This shows the iFn ring and ribbon cables.
    • Note the quadrature encoders for the iFn ring.
    • The XL1406_MF_PI_FPC_Rev04 cable has the quadrature encoders, and also runs to the connector at the front which connects to the internal focus motor and presumably sensors.
    • The XL1406 Switch FPC Rev04 connects to the iFn button and selector switches.
    • This shows the operation of the front section of the lens
    • The zoom functionality rotates the outer metal cylinder causing the inner sections to move within their races.
    • note the different angles of the slots causing the sections to move at different rates.
    • The focus mechanism sits inside this.
  16. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Front Nameplate: étape 20, image 1 de 2 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Front Nameplate: étape 20, image 2 de 2
    • Insert a fine flat blade (screwdriver or knife) under the flat ring with the lens details printed on it.
    • carefully slide around the circumference to release the glue
    • From this point, use a pencil to mark on the plastic pieces how they are oriented relative to each other. Remember the outer barrel can rotate, so you need to remember if its rotated to its maximum extent clockwise or anticlockwise.
  17. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Front Lens seal: étape 21, image 1 de 2 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Front Lens seal: étape 21, image 2 de 2
    • Use PH00 Screwdriver to remove the six screws holding the the seal cap.
    • Lift the plastic ring, and the foam seal underneath.
    • Note the foam gasket has a hole for a locating pin on the plastic ring.
    • Screw Size: 6@ M1.4 x 4.5mm with threadlock
  18. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Hood Bayonet Ring: étape 22, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Hood Bayonet Ring: étape 22, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Hood Bayonet Ring: étape 22, image 3 de 3
    • Use PH00 Screwdriver to remove the 3 screws holding the bayonet ring (and filter holder)
    • Screw Size: 3@ M1.6 x 6mm with threadlock
  19. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Front Lens: étape 23, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Front Lens: étape 23, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Front Lens: étape 23, image 3 de 3
    • Use PH0 driver to remove the 3 screws holding the front lens
    • Place the lens in a clean container to avoid contamination
    • Screws: 3@ M1.6 x 4mm wafer head
    • At this point we are left with the inner interlocking barrels.
    • The cover for the focus mechanism FPCB is also visible
  20. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Barrel Lip: étape 25, image 1 de 2 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Barrel Lip: étape 25, image 2 de 2
    • The rear end of the barrel assembly has a metal cap
    • Using PH00 Screwdriver remove the 4 screws
    • Screws: 4@ M1.4 x 3mm wafer head
    • Use a flat blade screwdriver to carefully lift the cap at multiple points around the circumference. It is a tight fit.
    • Be careful when removing it, as there is a plastic spacer underneath.
    • There appears to be places for two spacers, but only one was fitted in this lens.
  21. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove outer barrel: étape 26, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove outer barrel: étape 26, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove outer barrel: étape 26, image 3 de 3
    • Using a flat blade screwdriver remove the three special screws in the straight guides at the front of the lens.
    • Using a PH0 Screwdriver remove the 6 screws and spacers holding the two groups of lenses in place.
    • Do not loosen the screws with blue varnish inside white spacers. I'm guessing these are to align the lens elements.
    • The outer barrel can now be removed.
    • Remember to mark how things are aligned.
  22. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Focus Group: étape 27, image 1 de 2 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Remove Focus Group: étape 27, image 2 de 2
    • Remove the two screws holding the focus cable guard
    • Screws: 2@ M1.4 x 3mm
    • On the outside of the barrel you will see a small slot and a prong. This is the bottom end of the cable retainer.
    • Move the cable retainer inwards, there is a small amount of glue at the bottom that will separate.
    • The Focus group can now be removed
  23. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Review: étape 28, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Review: étape 28, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Review: étape 28, image 3 de 3
    • Some pictures of the focus element
    • Note the varnish / thread-lock on the screws inside the special white spacers. This is aligning the lenses.
    • The white spacers will be eccentric, so as they are rotated through 360 degrees (note the torx shaped inner wall), the lens will lift up or down, and then can be locked in place with the screw.
    • disassembling and reassembling this section will require marking each spacer exactly so that it can be put back in precisely the correct location.
    • Note the optical proximity sensor which is detecting the inner mechanisms endpoint (towards the motor).
  24. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, The Fault: étape 29, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, The Fault: étape 29, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, The Fault: étape 29, image 3 de 3
    • Inspecting the flex-pcb shows the likely fault. Over time the flex-pcb has developed a weak spot, which then becomes the point that flexes the most, causing it to weaken even further.
    • Flexing the cable shows that this spot is bending at a sharp angle.
    • Note how the main ribbon splits into two, one side going to the motor and the other to a sensor. The narrower ribbons could also have a fault as they also flex (orange), but in this lens the fault occurred during flexing of the main ribbon (changing zoom as the barrel elements move), not as focus changed. I will only be repairing the main ribbon.
  25. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Cable Analysis: étape 30, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Cable Analysis: étape 30, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Cable Analysis: étape 30, image 3 de 3
    • From the connector pinout we can follow the traces
    • Pin 1 (with white dot) - Pin 4 : These go to three traces in the flex PCB, and go towards the sensor. Pins 2 and 3 are joined.
    • Pins 5-8 : These go to the stepper motor. Pins 5 and 7 appear to be one winding, and pins 6 and 8 the other winding.
    • The wider copper strips on the outside and middle are not connected.
    • Flex ribbon details:
    • 0.07mm thick. There is at least 1mm gap between the focus elements and the inner barrel wall.
    • Stiffener thickness (at end with gold fingers) 0.30mm
    • As there are two weak spots (orange boxes) in the cable, the repair needs to run from before the first to after the second.
  26. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Initial Failed Repair Technique: étape 31, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Initial Failed Repair Technique: étape 31, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Initial Failed Repair Technique: étape 31, image 3 de 3
    • This is what I did after locating the faults on this particular lens.
    • Use masking tape to hold things in place while you work on them. I also cut some pieces of rigid foam to hold things in position. I recommend mounting this on a board that you can rotate for soldering at convenient angles. Cover the lenses (I used pieces of ziplock bag taped across) to avoid flux splash or dust while working.
    • Use a scalpel to scrape away some of the epoxy coating, being careful not to cut the copper traces.
    • Use some 34AWG stranded wire to replace the damaged section to flex PCB.
    • Use a multimeter to check the best you can, as you don't want to have to disassemble it again after testing.
    • Clean with flux remover on cotton swabs. Followed by IPA. Insulate with kapton/polyamide tape. Use double sided tape to reattach cables where they need to go.
    • Soldering the ribbon was very difficult. The traces were ~0.1 - 0.2mm wide. Stagger the soldering positions to help avoid shorts. At this stage I'm giving this repair job a 20% chance of success. If this doesn't work I will manufacturing a new flex ribbon - although I fitting to the motor will be challenging without removing the calibration screws.
  27. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Focus group extra pictures: étape 32, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Focus group extra pictures: étape 32, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Focus group extra pictures: étape 32, image 3 de 3
    • Some extra pictures of the focus mechanism.
  28. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Manufacture new Flex PCB: étape 33, image 1 de 2 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Manufacture new Flex PCB: étape 33, image 2 de 2
    • After the initial failed repair attempt using thin wire, a Flex PCB was designed to splice into the stubs of the original flex PCB going to the motor and sensor.
    • JLCPCB.com was used to make the cables, but other suppliers could be used. The second picture shows the manufacturing details.
    • See https://github.com/mostlyhorses/XL1406_A... for the PCB gerber files
    • You will want at least 3 cables so you have something to practice on.
  29. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Disassemble Flex PCB Holder: étape 34, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Disassemble Flex PCB Holder: étape 34, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Disassemble Flex PCB Holder: étape 34, image 3 de 3
    • Cut the original flex PCB from the focus mechanism (red lines in first picture), leaving a tail from the motor and sensor for splicing onto replacement cable.
    • Notice how the flex PCB is adhered and folded into the metal carrier, including how the tape has been placed.
  30. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Splice in replacement FPCB: étape 35, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Splice in replacement FPCB: étape 35, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Splice in replacement FPCB: étape 35, image 3 de 3
    • Scrape the coverlay off the original flex pcb so that it can be soldered to. Be careful not to damage the traces as you don't have much to work with.
    • Join the new flex pcb to the stubs. This was more difficult than I hoped, as the solder would not bridge across the 0.07mm height difference reliably. The technique I used was
    • Use the double sided tape to attach the stub to the long tail of the splice PCB.
    • Use a much cooler soldering iron than usual, so that the solder can be 'moulded' as you push it around with the iron tip. If you get the right temperature it will be much easier.
    • Bridge the outer traces and the guard sections of PCB so you can use a large blob of solder here, which will bridge the gap between the two PCBs. Note how I've cut a piece out of the guard section so it doesn't join the motor and sensor.
    • On the inner traces use a fine strand of wire to join the sections.
    • Insulate the soldering with polyamide tape and reattach it to the body using double sided tape.
    • Check with a multimeter that the traces are connected and not shorting. Note that Pins 5 and 7 are one motor winding, and pins 6 and 8 the other, so they will measure as connected, but as they have a trace between them you can tell it's intentional and not a soldering short.
    • Use the Helimax-XP grease to lubricate the barrels and other rotating parts. I didn't apply enough, but I don't want to open the lens again to add more.
    • When re-installing screws into plastic, gently turn them backwards (anti-clockwise) until you feel the thread engage before tightening them clockwise.
    • Don't overtighten the screws
  31. Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Result: étape 37, image 1 de 2 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Result: étape 37, image 2 de 2
    • Take some test picture at different focal lengths to check auto-focus works and that nothing is out of alignment.
Ben Moores
Membre depuis le 05/24/19
445 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 30
Total : 88
