Aller au contenu principal
Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair
Anglais
Français
Traduction de l’étape 31
Étape 31
Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Initial Failed Repair Technique: étape 0, image 1 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Initial Failed Repair Technique: étape 0, image 2 de 3 Samsung NX 50-150 f/2.8 S Lens - Focus Cable Repair, Initial Failed Repair Technique: étape 0, image 3 de 3
  • This is what I did after locating the faults on this particular lens.
  • Use masking tape to hold things in place while you work on them. I also cut some pieces of rigid foam to hold things in position. I recommend mounting this on a board that you can rotate for soldering at convenient angles. Cover the lenses (I used pieces of ziplock bag taped across) to avoid flux splash or dust while working.
  • Use a scalpel to scrape away some of the epoxy coating, being careful not to cut the copper traces.
  • Use some 34AWG stranded wire to replace the damaged section to flex PCB.
  • Use a multimeter to check the best you can, as you don't want to have to disassemble it again after testing.
  • Clean with flux remover on cotton swabs. Followed by IPA. Insulate with kapton/polyamide tape. Use double sided tape to reattach cables where they need to go.
  • Soldering the ribbon was very difficult. The traces were ~0.1 - 0.2mm wide. Stagger the soldering positions to help avoid shorts. At this stage I'm giving this repair job a 20% chance of success. If this doesn't work I will manufacturing a new flex ribbon - although I fitting to the motor will be challenging without removing the calibration screws.
Insérez ici votre traduction
