Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Repeat to remove the second adhesive strip. If you removed both strips successfully, skip the next two steps. If either of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strip, and then proceed to the next step.
  • Repeat to remove the second adhesive strip.
  • If you removed both strips successfully, skip the next two steps.
  • If either of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strip, and then proceed to the next step.
Tirez tout droit la bande adhésive extérieure de la batterie et passer soigneusement autour de l'ange de la batterie.
Tirez la batterie le long du bord de la batterie jusqu'à ce qu'elle se libère du téléphone.
[* black] PullRepeat to remove the outside batterysecond adhesive tab straight up and carefully around the corner of the batterystrip.
[* black] PullIf you removed both strips successfully, skip the strip along the edgenext two steps.
[* icon_caution] If either
of the adhesive strips break underneath the battery until it is freed fromand cannot be retrieved, try to remove the remaining strip, and then proceed to the phonenext step.
