Aller au contenu principal
Changement écran tactile Nintendo 3DS XL
Anglais
Français
Traduction de l’étape 1
Étape 1
Nintendo 3DS XL Touchscreen Replacement: étape 0, image 1 de 2 Nintendo 3DS XL Touchscreen Replacement: étape 0, image 2 de 2
  • Open the device's hinge.
  • Gently press upward on the touchscreen until it separates from the casing.
  • If you are replacing the touchscreen assembly (touch digitizer & display), this is the final step. Continue to the next step if you are replacing the display separately from the touch digitizer.
Ouvrez la charnière de l'appareil.
Appuyez doucement vers le haut sur l'écran tactile jusqu'à ce qu'il se sépare du boîtier.
[* black] Open the device's hinge.
[* black] Gently press upward on the touchscreen until it separates from the casing.
+[* icon_note] If you are replacing the touchscreen assembly (touch digitizer & display), this is the final step. Continue to the next step if you are replacing the display separately from the touch digitizer.
