Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 7
Étape 7
Using a plastic opening tool pop off the circle pad joystick. Do not use excessive force with the plastic opening tool. There is a ribbon attaching the circle pad joystick to the motherboard that will remain attached.
  • Using a plastic opening tool pop off the circle pad joystick.
  • Do not use excessive force with the plastic opening tool. There is a ribbon attaching the circle pad joystick to the motherboard that will remain attached.
  • There is a loose washer located in between the circle pad joystick and the circle pad. Use caution and do not lose this piece.
Insérez ici votre traduction
