Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 19 tutoriels qui comprennent cette étape.
Traduction de l’étape 3
Étape 3
Lift up the right end of the clutch cover while guiding the display data and iSight cables through the gap and the two hooked tabs at the right end of the clutch cover. If the cables snag on the two hooked tabs, free them carefully.
Lift the clutch cover off of the display assembly.
- | [* black] Lift up the right side of the clutch cover and guide the display data and iSight cables through the gap in the clutch cover. |
- | [* black] Lift the clutch cover out of the display assembly. |
- | [* icon_reminder] During reassembly, make sure not to pinch the backlight cable (with the white connector) when snapping the clutch cover back into place. This cable has two visible wires leading into the lower right section of the LCD display to the backlight. (The models with pink and white wires are usually longer and easier to pinch.) |
+ | [* black] Lift up the right end of the clutch cover while guiding the display data and iSight cables through the gap and the two hooked tabs at the right end of the clutch cover. If the cables snag on the two hooked tabs, free them carefully. |
+ | [* black] Lift the clutch cover off of the display assembly. |
+ | [* icon_reminder] During reassembly, avoid pinching the display data and iSight cables. While guiding the right end of the clutch cover into place, but before snapping it down, guide these cables between the two hooked tabs inside the right end of the clutch cover, and up into the curved area of the clutch cover, above the hinge. |
+ | [* icon_reminder] Also avoid pinching the backlight wires (with the white connector on the end, plugged into the right end of the inverter). They should run under the upper right edge of the clutch cover. In some models, the two wires are gray and black, and in others they're white and pink. They lead into a hole in the lower right edge of the LCD to the backlight. |
