Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Traduction de l’étape 1
Étape 1
Unplug the charger and remove any memory card you may have in the device.
Wedge the plastic opening tool between the front and back cover on every side.
Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
Once disconnected, remove the back cover from the device screen.
- | [* black] Plug out the charger and pull out the memory card if connected as a preliminary step. |
[* icon_caution] Make sure that the device is turned off as a precaution. | |
- | [* black] Wedge the plastic opening tool between the front and back cover on every side as shown on the photos. |
+ | [* black] Unplug the charger and remove any memory card you may have in the device. |
+ | [* black] Wedge the plastic opening tool between the front and back cover on every side. |
[* black] Slide the plastic opening tool back and forth to make sure that the back cover is disconnected. | |
- | [* black] |
+ | [* black] Once disconnected, remove the back cover from the device screen. |
