Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Traduction de l’étape 4
Étape 4
Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
- | [* red] Locate the battery cable attached to the motherboard. |
- | [* black] |
- | [* icon_note] When |
+ | [* red] Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery. |
+ | [* black] Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery. |
+ | [* icon_note] When separating the metal frame, be sure to hold on in the center as the battery is two separate cells. |
