Aller au contenu principal
Digitac Jazz Ultratab C725 Charging Port Replacement
Anglais
Français
Traduction de l’étape 2
Étape 2
Digitac Jazz Ultratab C725 Charging Port Replacement: étape 0, image 1 de 3 Digitac Jazz Ultratab C725 Charging Port Replacement: étape 0, image 2 de 3 Digitac Jazz Ultratab C725 Charging Port Replacement: étape 0, image 3 de 3
  • Flip your device so that the long side without the buttons is facing you.
  • Insert the plastic opening tool between the silver back plate and the screen. From the corner of the device on either side, pry the seam of the device about 1 inch.
  • With the plastic opening tool, pry the screen apart from the back plate.
  • Keep prying the screen apart from the back plate until they are separated.
  • With the plastic opening tool, if necessary, pry apart the remaining seams of the device.
  • After the screen is loose, pull the screen towards you. Lift it to prevent damage to the buttons.
Insérez ici votre traduction
