Traduction de l’étape 2
Étape 2
Battery Compartment Door Removal
Place the camera down so that the lens is facing up.
Remove the single 4 mm screw from the inside of the battery compartment using a Phillips #00 screwdriver.
Remove the door from the camera.
[title] Battery Compartment Door Removal | |
[* black] Place the camera down so that the lens is facing up. | |
- | [* red] Next, use the Phillips #00 Precision Screwdriver to unscrew the inner most 4 mm phillips head screw. This will remove the door from the camera. |
- | [* icon_reminder] Always place screws on the the Magnetic Mat and write the size and location of where they were removed from with a dry erase marker. |
+ | [* red] Remove the single 4 mm screw from the inside of the battery compartment using a Phillips #00 screwdriver. |
+ | [* black] Remove the door from the camera. |
+ | [* icon_reminder] Always place screws on a magnetic mat and write the size and location of where they were removed to know where to place them back. |
