Aller au contenu principal
Remplacement du boitier du Sony Cyber-shot DSC-W570
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Sony Cyber-shot DSC-W570 Case Cover Replacement: étape 0, image 1 de 2 Sony Cyber-shot DSC-W570 Case Cover Replacement: étape 0, image 2 de 2
  • Face the device with the camera lens facing upwards
  • Now that all the screws are unscrewed, the plastic opening tool will be used to remove the front cover.
  • Gently pry off each corner of the cover to remove it
  • Once all corners are pried off, gently lift off the cover and place it on the side
Pour retirer le capot avant, utilisez un outil d'ouverture en plastique pour soulever doucement le capot supérieur.
Puis soulevez doucement le couvercle.
-[* black] To remove the front cover, use a plastic opening tool gently pry the top cover.
-[* black] Then gently lift the cover off.
+[* black] Face the device with the camera lens facing upwards
+[* icon_note] Now that all the screws are unscrewed, the plastic opening tool will be used to remove the front cover.
+[* black] Gently pry off each corner of the cover to remove it
+[* black] Once all corners are pried off, gently lift off the cover and place it on the side
