Aller au contenu principal
Canon PowerShot SD200 Battery Replacement
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Canon PowerShot SD200 Battery Replacement: étape 0, image 1 de 3 Canon PowerShot SD200 Battery Replacement: étape 0, image 2 de 3 Canon PowerShot SD200 Battery Replacement: étape 0, image 3 de 3
  • The camera used to create these repair guides had a broken lens assembly. As a result, the lens is sticking out in all of the photos, but it is important to note that this should not be the case with your camera. The lens should retract itself back into the camera when it is turned off.
  • Use your fingernail to slide the dark gray tab located on the bottom of the device towards the edge of camera.
  • Slide the light gray door away from the LCD screen and pull up to open the door.
  • Both battery and memory card should now be visible.
Insérez ici votre traduction
