Aller au contenu principal
Canon PowerShot S100 Outer Case Replacement
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Canon PowerShot S100 Outer Case Replacement: étape 0, image 1 de 3 Canon PowerShot S100 Outer Case Replacement: étape 0, image 2 de 3 Canon PowerShot S100 Outer Case Replacement: étape 0, image 3 de 3
  • Turn the camera so that the lens is facing you.
  • Do not pull the front panel off without removing the ribbon cable first.
  • Slowly lift the front panel from the camera.
  • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
  • A spudger may also be used to remove the ribbon cable.
  • Remove the rubber guard that rests on top of the lens.
Insérez ici votre traduction
