Aller au contenu principal
Canon PowerShot S100 Outer Case Replacement
Ricky
Ricky et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
10 minutes
Facile
Removing the body cover is necessary to access other parts inside the camera.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon PowerShot S100 Outer Case Replacement, Outer Case: étape 1, image 1 de 3 Canon PowerShot S100 Outer Case Replacement, Outer Case: étape 1, image 2 de 3 Canon PowerShot S100 Outer Case Replacement, Outer Case: étape 1, image 3 de 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Outer Case Replacement: étape 2, image 1 de 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Outer Case Replacement: étape 3, image 1 de 3 Canon PowerShot S100 Outer Case Replacement: étape 3, image 2 de 3 Canon PowerShot S100 Outer Case Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
Ricky
Membre depuis le 02/23/15
968 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Leahy Winter 2015 Membre de l'équipe USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 13
Total : 1,213
