Aller au contenu principal
Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 0, image 1 de 3 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 0, image 2 de 3 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 0, image 3 de 3
  • Using the plastic opening tool, detach the wires connected to the metal plate
  • When disconnecting the wires, be careful not to pull on the wires themselves. Use the plastic opening tool and the connector to disconnect it.
  • Use the plastic opening tool to remove wires connected to the circuit board on the far right.
  • Use the tweezers to remove wires connected to the circuit board in between the two black wires.
  • Use the tweezers to press the release tab on the front and back of the plastic white wire head.
  • Once the tab is pressed on both sides, lift up to slide wire head out of socket.
Insérez ici votre traduction
