Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Traduction de l’étape 1
Étape 1
You should now see the EMI filter right in the middle of the device (although held in by a few other components).
Follow the wires coming out of the bottom of the Power adapter off to the left.
Take the tweezers and remove the piece of tape holding the wires to the casing.
There is only one connector that needs to be taken out (even though there are two right next to each other!).
Grab the connector from the bottom and pull it carefully from its corresponding socket.
- | [* black] You should now see the |
+ | [* black] You should now see the EMI filter right in the middle of the device (although held in by a few other components). |
[* black] Follow the wires coming out of the bottom of the Power adapter off to the left. | |
- | [* black] Take the tweezers and remove the piece of tape holding the wires to the casing. |
+ | [* black] Take the [product|IF145-020|tweezers] and remove the piece of tape holding the wires to the casing. |
[* black] There is only one connector that needs to be taken out (even though there are two right next to each other!). | |
[* black] Grab the connector from the bottom and pull it carefully from its corresponding socket. |
